Select Entities
Window Selection Settings
Change window selection settings from the modeling window right-click context menu.
Figure 3.
- Window Select Disabled. Disable window selection. Allows for fast clicking without the risk of dragging a mini window.
 - Window Shape. Change the shape of the selection window when you drag your mouse.
 - Intersection -  Select entities that are inside,
          outside, or intersecting the window shape.Note: Intersection is available for elements, lines, and surfaces.
 - Only Select Visible. Only select visible entities. Available for elements.
