Run Matrix
Load your own design matrix.
1.0 | 2.0 | 3.0 | 4.0 |
4.1 | 4.3 | 4.5 | 4.6 |
6.7 | 8.1 | 10.0 | 11.0 |
17.2 | 1.0 | 1.0 | 3.0 |
.02 | 0.4 | 0.5 | 1.7 |
3.4 | 2.1 | 7.3 | 9.1 |
Usability Characteristics
- Create your own design based on individual requirements.
- The matrix does not have to fit any DOE type requirements. You can use it to automate a parameter study.
- The run matrix uses exact values of the variable. This is in contrast to the user defined DOE, which contains integers to represent the corresponding level of the variable.
- It is not necessary to utilize all designs in a study. Designs that are not desired can be turned off from the Write/Execute runs panel.
- Imported values are mapped to the independent variables.
- Any data in the inclusion matrix is combined with the run data for post-processing. Any run matrix point which is already part of the inclusion data will not be rerun.
Settings
Parameter | Default | Range | Description |
Matrix File | File that has the dataset for your own design of matrix. | ||
Use Inclusion Matrix | Off | Off or On | Concatenation without duplication between the inclusion and the generated run matrix. |
