User Defined Design
Load your own design matrix.
9 | 3 | |
1 | 1 | 1 |
1 | 2 | 2 |
1 | 3 | 3 |
2 | 1 | 3 |
2 | 2 | 2 |
2 | 3 | 1 |
3 | 1 | 2 |
3 | 2 | 3 |
3 | 3 | 1 |
Usability Characteristics
- Create your own design based on individual requirements.
- The User Defined matrix uses integers to represent the corresponding level of the variable. This is in contrast to the run matrix DOE, which contains exact values of the variables.
- The number of levels specified in the file must be consistent with the number of variable levels specified in the HyperStudy user interface.
- Imported values are mapped to the independent variables.
- Any data in the inclusion matrix is combined with the run data for post-processing. Any run matrix point which is already part of the inclusion data will not be rerun.
Settings
Parameter | Default | Range | Description |
Perturb File | File that has the dataset for your own design of experiments. | ||
Use Inclusion Matrix | Off | Off or On | Concatenation without duplication between the inclusion and the generated run matrix. |
