A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
Use the context Tcl API commands to
programmatically interact with the client contexts.
Use these commands to query, modify and interact with an active context. The commands
also contain necessary mechanisms to create custom scripted contexts using
itcl.
Note: Some of the commands and their
methods are client-specific, as stated in the description and the input
details.
