hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Calculates the range between file locators.
Indicates if the last of a specified entity is read.
Creates storage in memory where you can store a block of file locators.
Frees the memory that was used for file locators.
Determines if an entity is present within the given file.
Provides a way to reposition the file.
Assigns a location for the file locator.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
