HMIN_filelocator_continuereading()
Indicates if the last of a specified entity is read.
int HMIN_filelocator_continuereading(void * filelocatorptr, int filelocator, FILE * file);
HyperMesh hminlib Function
- locatorptr
- A pointer to the block of file locators.
- filelocator
- The index into the block of file locators.
- File
- The entity to be read.
1, if it has not read through to the end of the block.
0, if it has reached the end of the block.
None.
