hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Copies a string of absolute length.
Checks the characters in a string for those considered valid for a double field.
Checks the characters in a string for those considered valid for an integer field.
Counts the number of occurrences of a character in a string.
Deletes a string of characters from a string.
Performs a string compare, ignoring upper and lower case.
Inserts a string into another string.
Inserts a character into a string.
Converts the characters in a string to lower case.
Replaces a string within a string.
Removes end of line spaces.
Removes leading and trailing spaces from a string.
Converts the characters in a string to upper case.
Extracts the integer value from a string.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
