A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration
point results or node-on-element results.
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s,
this function returns 0 because these elements have a variable number of nodes.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
HM_elementconfiggetnumberofnodes()
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s, this function returns 0 because these elements have a variable number of nodes.
HM_entitynamegettype()
Returns the HyperMesh #defined type number of an entity, given its name.
HM_entitytypegetname()
Returns the name of an entity, given the HyperMesh #defined type number.
