Command Files
Command files can be used to create new command scripts that perform automation, or to recover previously performed steps.
While the application is open, it generates a Tcl file named command<#>.tcl on Windows, and command.tcl on Linux. This file is created at the start of a session if it does not exist. If the file already exists, the application adds the commands for the new session to the end of the original file.
*createmark elements 1 "all"
*deletemark elements 1
