Marks
Marks specify groups of entities that are transferred to the command processor. Marks can be created for most entities, and commands are then issued to perform operations on the entities on the mark. HyperMesh allows for two standard marks and a user mark.
Standard marks are referenced by the mark IDs 1 and 2. The following example demonstrates how to delete elements using standard marks; assume that you want to delete the elements 50, 51, and 52 from a database. To perform this operation, you must create a mark with these elements and then instruct HyperMesh to delete the mark:
*createmark elems 1 "50 51 52"
*deletemark elems 1
This *createmark command populates mark 1 with elements 50, 51, and 52. The *deletemark command deletes the elements contained on mark 1.
In addition, Boolean operation commands such as *markdifference and *markintersection allow for interactions between the two marks, performing specific comparisons between the entities contained in mark 1 and mark 2.
The user mark allows entities to be saved or retrieved both from within the HyperMesh panels as well as from commands. The *marktousermark command allows the entities contained on one of the standard marks to be placed on the user mark. The Tcl command hm_getusermark returns the IDs for the entities stored on the user mark.
The user mark can also be accessed with the extended entity selection "retrieve" option from any panel where that particular entity can be selected. Similarly, the extended entity "save" option saves the selected entities to the user mark.
