HMIN_hmxfilename()
Returns the name of the HMX file.
char* HMIN_hmxfilename();
HyperMesh hminlib Function
Returns the name of the generated HMX file.
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Saves supplied text to an .hmx file.
Allows you to send a message to the message file while a database is being read in.
Sets the file extension for the unsupported data log file.
Sets the directory where the HMX file is created.
Writes a status message to the menu header bar.
Writes an error message to the menu header bar (in red).
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
None.
ON THIS PAGE
