HMRES_displacementadd()
Adds a displacement value to the results file of the data type.
int HMRES_displacementadd(HM_entityidtype id, double x, double y, double z);
HyperMesh hmreslib Function
- id
- The ID of the node at which the displacement occurs.
- x
- The x coordinate of displacement.
- y
- The y coordinate of displacement.
- z
- The z coordinate of displacement.
Zero, if successful; otherwise, nonzero.
Before a displacement can be stored in the results database, a simulation and data type must be opened.
The data type that is currently open when this function is called must be capable of storing nodal displacements.
None.
