HMRES_magnitudephasetorealimaginary()
Use to convert a complex number in magnitude/phase format to real/imaginary format. This function modifies the values passed.
void HMRES_magnitudephasetorealimaginary(double *magnitude, double *phase);
HyperMesh hmreslib Function
magnitude
The magnitude of a complex number in polar form.
phase
The phase of a complex number in polar form in degrees.
None.
