HWC Console Command Syntax
The HWC command syntax is case insensitive.
Multiple Commands per Line
hide all | mark component dictionaryrange "SHELL: TIRE-FRONT-LEFT" "SHELL: TIRE-RIM-OUTER.3" | show component marked
ID Range Lists
show component 2000770-2000780,2000083
Label Lists
show component "BIW - A pillar bracket 5 - R - I" ,"BIW - B pillar reinfor 2 - R - I" ,"BIW - control module brkt"
mark sset "Set 1" ,"Set 2" ,"Set 5"
Wildcards
show component 20001*, 20007*,
hide component *pillar*,*floor*
