rpti::frwk
Enables you to execute and export report.
rpti::frwk addconverter
Add converter class, used for version management.
- Syntax
- Parameters
- class
- Value: Class Name that implements conversion process.
rpti::frwk addcustompackage
Registers .tcl package to load containing custom module.
- Syntax
- Parameters
- -directory
- Value: Directory that contains .tcl package.
- -packagename
- Value: Name of .tcl package.
- Returns
- 1 for OK; .tcl-error in case of error.
rpti::frwk addcustompath
Registers additional search path(s) to locate custom modules.
- Syntax
- Parameters
- -directory
- Value: One or a list of paths separated by blank.
- Returns
- 1 for OK, .tcl-error in case of error.
rpti::frwk addview
Add/Register a view for update callbacks.
- Syntax
rpti::frwk addview
- Parameters
- view
- Value: View/widget that implements update callbacks.
rpti::frwk appendtemplate
Appends the specified report template to existing report template.
- Syntax
- Parameters
- -file
- Value: File name of report template.
- Returns
rpti::frwk execute
Executes the current report template.
- Syntax
rpti::frwk execute
- Parameters
- -id
- Value: ID of the items to be executed.
- Returns
- 1 for OK
rpti::frwk export
Exports the Ms-office report based on current report template.
- Syntax
rpti::frwk export
- Parameters
- -file
- Value: File name of Ms-office report including extension.
- Returns
- 1 for OK, .tcl -error in case of error.
rpti::frwk geterrorcount
Get number of errors.
- Syntax
- Parameters
- None
rpti::frwk getexportitems
Get number of items marked for export.
- Syntax
- Parameters
- None
rpti::frwk getinterface
Get Frwk Interface.
- Syntax
- Parameters
- -name
- Value: Report session name.
- Returns
- Framework Interface Object
rpti::frwk getmasterdocument
Queries the current Ms-office master template file based on current report format (document, presentation).
- Syntax
- Returns
- The current Ms-office master template file.
rpti::frwk getreporttype
Queries the Ms-office report type.
- Syntax
- Returns
- The current Ms-office report type (word, ppt).
rpti::frwk getunexecuteditems
Get number of non-executable items.
- Syntax
- Parameters
- None
rpti::frwk getworkdir
Queries the current work directory.
- Syntax
- Returns
- The current work directory.
rpti::frwk ispaused
Check if report execution is paused.
- Syntax
rpti::frwk ispaused
rpti::frwk::isrunning
Check if report is running.
- Syntax
rpti::frwk isrunning
rpti::frwk isstarted
Check if report execution started.
- Syntax
rpti::frwk loadtemplate
Loads the specified report template.
- Syntax
- Parameters
- -file
- -filelist
- Value (optional): List of file names as seen in the Report Template dialog or as passed or as used in the order of running HyperMesh in batch mode.
- Returns
rpti::frwk newreport
Creates new report template.
- Syntax
- Parameters
- -type
- Value: Type of report (word, ppt).
- Returns
rpti::frwk pause
Flags pause execution.
- Syntax
rpti::frwk pause
rpti::frwk quit
Quits Report.
- Syntax
rpti::frwk quit
- Parameters
- None
- Returns
rpti::frwk redraw
Notifies all registered views to redraw itself.
- Syntax
rpti::frwk redraw
rpti::frwk registertype
Register a new type relating to an editor.
- Syntax
- Parameters
- -type
- Value: Unique one-word, all lowercase identifier for the new type. This is the identifier you will need to specify in the module's .xml file.
- -class
- Value: ITcl class that contains the editor code. Make sure to use proper name space for your custom editor to avoid naming clashes.
- Returns
rpti::frwk removeview
Remove already registered views.
- Syntax
- Parameters
- view
- Value: View/widget registered.
rpti::frwk reset
Resets the execution flags.
- Syntax
rpti::frwk reset
rpti::frwk resume
- Syntax
rpti::frwk resume
rpti::frwk savetemplate
Saves the current report template.
- Syntax
- Parameters
- -file
- Returns
rpti::frwk setmasterdocument
Sets the Ms-office master template based on current report format (document, presentation).
- Syntax
- Parameters
- -file
- Value: Ms-office master template file.
- Returns
rpti::frwk setworkdir
Sets the work directory to specified path.
- Syntax
- Parameters
- -directory
- Value: Path of work directory.
- Returns
rpti::frwk start
Starts ARD in desired mode.
- Syntax
rpti::frwk start
- Parameters
- -mode
- Values: Interactive (interactive with GUI) mute (engine only, no GUI).
- Returns
rpti::frwk startexec
Flags execution start.
- Syntax
rpti::frwk stop
Flags stop execution.
- Syntax
rpti::frwk stop
rpti::frwk templateloadpostcommand
Specify the callback to be called after a new report template got loaded.
- Syntax
- Parameters
- -command
- Value: Command, .tcl procedure or ITcl method to be called.
- Returns
rpti::frwk templateloadprecommand
Specify the callback to be called before a new report template is being loaded.
- Syntax
- Parameters
- -command
- Returns
rpti::frwk validate
Validate an item.
- Syntax
rpti::frwk validate
- Parameters
- -id
- Value: Specify item ID to validate.
