rpti::item
Add, access or modify report items.
Interact with report items.
Supported Property Names
-name -value -parent -type (read only) -caption -config -itemlist -itemproperties(readonly) -istemplate -clientdata -icon -expand -execute -export -enable -visible -layoutname(presentation only).
All properties available can accessed via item get API and modified via the set API.
