Transpose operator.
expr'
Operands
- expr
- A valid scalar, vector, or matrix expression.
| Expression | Result |
1' |
1 |
{1, 2, 3}'
{ {1}, {2}, {3} }
{ {1}, {2},{3} }'
{1, 2, 3}
{ {1, 2}, {3, 4} }'
{ {1, 3}, {2, 4} }
If expr is a matrix, the elements of the matrix are interchanged such that the rows of the original matrix become the columns of the resultant matrix.
If expr_2 is a row vector, the result is a column vector with identical elements.
If expr_2 is a column vector, the result is a row vector with identical elements.
If expr_2 is a scalar, the result is expr_2.
