hgtrans config SetChannelSelected
Marks a data channel for translation.
hgtrans config SetChannelSelected subcase, datatype, request, component, state
HyperGraphTrans Tcl Set
This command marks a single channel in the source file for translation.
subcase
The name of the subcase from which to read.
datatype
The name of the datatype from which to read.
request
The name of the request from which to read.
component
The name of the component from which to read.
state
True or false; whether to read from this channel or skip it.
Cause hgtrans to read a single channel from a file called “columns.dat” and save it to “columns.abf
hgtrans control SetFile "columns.dat"
hgtrans control SetOutputFile "columns.abf"
hgtrans config SetChannelSelected "" "Unknown" "Res. ang acc (rad/s**2)" "column 2" true
hgtrans control StartTranslation
None.
Keywords
set channel selection
