plt3DICursor FindLocalMin
Moves the cursor to the local minimum of one component of the plot along an axis.
plt3DICursor_handle FindLocalMin component axis direction
Tcl Query
- component
- The component (X, Y, or Z).
- axis
- The axis to scan (X, Y, or Z).
- direction
- Either "forward" or "backward".
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAxisHandle mySurfaceName 1
mySurfaceName GetCursorHandle myCursorName 1
myCursorName FindLocalMin "z" "x" forewardErrors
If no further minima exist, the cursor is not moved.
