plt3DICurve AddPoint
Adds a point to a 3D curve and optionally sorts the points.
plt3DICurve_handle AddPoint x y z sort_axis
Tcl Query
The points in the curve are sorted after each insertion if a direction is specified (not blank).
- x
- The new X value (abscissa).
- y
- The new Y value (ordinate).
- z
- The new Z value (altitude).
- sort_axis
- X, Y, Z or blank ("").
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName AddCurveGroup
myClientName GetCurveGroupHandle myGroupName 1
myGroupName AddCurve
myGroupName GetCurveHandle myCurveName 1
myCurveName AddPoint 0 0 0 ""Errors
None.
