plt3DICurveGroup GetNumberOfCurvesOnClipboard
Gets the current number of curves in the curve group.
plt3DICurveGroup_handle GetNumberOfCurvesOnClipboard
Tcl Query
All curve groups share a single clipboard, which can contain (in theory) one or more curves. The current implementation limits the number of curves that can be on the clipboard at a time to one (or zero).
Returns the number of curves (currently zero or one).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName GetNumberOfCurvesOnClipboardErrors
Returns an empty string if the value is not defined.
