plt3DINote SetJ
Sets the note’s J position.
plt3DINote_handle SetJ
Tcl Query
This command sets the note’s J position. The J position is the row position of the note attachment point.
Note: This command will not work unless the note is attached to something.
j
The input for the j variable is the row value (j position along the i axis) of the attachment point of the note.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetNoteHandle n1 1;
n1 SetJ 50;
Success (0) or an error is returned.
Keywords
  • Tcl
  • Note
  • Plot 3D
  • Query
