plt3DISurface GetMeshColor
Gets the color of mesh lines superimposed on the surface.
plt3DISurface_handle GetMeshColor
Tcl Query
The string returned will be either a color name, if the RGB values of the color match a name, an index, if the value matches one of the standard palette of colors, or a set of three RGB values.
Returns a color identifier string.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName GetMeshColorErrors
None.
