The following image displays the Create Property Cards submenu.
Assign Thickness |
Opens a dialog to assign/extract thickness to part elements and organize them  |
Shell Mesh |
Opens a selector for elements so that you can assign property cards for other surface meshes such as Moldbase, Mold insert and Part insert.  |
Create Runner |
Opens a dialog so that you can create the runner system by specifying the geometrical parameters  |
Edit Runner |
Opens a selector for elements so that you can select the elements that you want to edit the properties  |
Coolant Channel |
Opens a selector for elements so that you can assign/edit the properties for coolant channel and heating rod  |
Points |
Opens a selector for node so that you can assign property such as Fix Node, Sensor Node, Valve Gate Control Point Node and so on  |
BCs |
Opens a selector for node so that boundary conditions such as Melt Entrance, Coolant Entrance and Coolant Exit can be defined on the node  |
<<<Back |
Opens the main Moldex3D Shell Utility menu.  |
