The Moldex3D Shell Utility Menu consists buttons that provide shortcuts to functionalities in HyperMesh. The layout of the buttons mimic the process flow required to set up a model for Moldex3D Shell.
The main Utility Menu is shown below, along with descriptions of each macro button.
Tools  |
Midplane Wizard |
Opens the Midplane Wizard tab, which contains a step-by-step procedure to set up a midplane injection molding input data. See the Midplane Wizard submenu.  |
Surfaces |
Cleanup |
Shortcut to the Edge Edit panel. This shortcut provides quick access to the Edge Edit, Defeature, and Point Edit panels for geometry cleanup operations.  |
Midsurface |
Shortcut to the Midsurface panel, which provides tools to extract a midsurface from selected surfaces.  |
Lines |
Create |
Shortcut to the Lines panel, which is used to create lines.  |
Edit |
Shortcut to the Line Edit panel, which is used to edit lines.  |
Shell Mesh |
Opens the panel to generate surface mesh (tria).  |
Runner System Mesh |
Opens the panel to generate 1D beam mesh for the runner  |
Coolant System Mesh |
Opens the panel to generate 1D beam mesh for the coolant channel.  |
Model Setup  |
Create Property Cards |
Opens a submenu for setting up the model. See Create Property Cards for details.  |
Diagnostics |
Computes the element quality of the displayed solid elements.  |
Export |
Opens the Moldex3D MSH Export dialog for exporting the model. See Export for details.  |
