Once the boundary conditions have been set up and assigned, the process parameters should be defined. The process parameters allow you to control the run by specifying the equations/physics to be solved and defining control parameters such as convergence tolerances and the number of iterations/time steps.
Click Parameters on the RTM Utility menu. The Define Altair RTM Analysis Parameters dialog contains the following tabs:
The density and compressibility of the air are dependent on air pressure. These two parameters automatically computed when the air pressure value is changed.
This panel is used to specify special commands to control the job. This is an advanced feature.
