The Extract Points macro defines the locations in the model where results are required for comparing with existing experimental data or for other validation/optimization purposes. You can pick these points at nodal locations or at any coordinate location inside the domain. If the point selected is outside the domain, RTM ignores it at the time of solution.
| 1. | Enter the number of extract points and click Update. |
| 2. | Select each point by picking a node or entering the coordinate locations. |
| 3. | Click Update to register the changes in the HyperMesh database. |
| 4. | Click Close. |
