The Layered Tet Mesh submenu contains the following macros:
Define Boundary Areas  |
Create CompsShortcut to the Components panel.  |
Surface MeshShortcut to the Automesh panel.  |
NormalsShortcut to the Normals panel.  |
Organize FacesShortcut to the Organize panel.  |
Def. BL ThicknessOpens the Generate Boundary Layer distributed thickness values dialog, where you can generate boundary layer thickness for components with 2D mesh.  |
Create Layered Tet Mesh  |
CFD Tet Mesh Shortcut to the CFD Tetramesh panel.  |
Split Prism to Tets Allows you to split all prisms (5-noded pyramids) to tetras  |
Split BC Tets Allows to you split tetra elements on the boundary so that no element shares more than one face on the boundary  |
