Schematic and Equations
This model can be used for both dynamic and quasi-static tests.
- X is the input displacement provided to the bushing.
- y and w are the internal states of the bushing.
- and represent the bushing rubber stiffness.
- is used to control the stiffness at large velocities.
- produces the roll-off observed in the experimental data at low velocities.
- accounts for the relaxation of the bushing impact force.
- represents the viscous damping observed at large velocities.
- R is the cutoff frequency associated with a first order filter that acts on the input X.
- x is the dynamic content of the bushing input X. This is the filter output.
- and are the time derivatives of the internal states of the bushing y and w.
- K is the effective stiffness of the bushing.
- C is the effective damping of the bushing.
- Spline (X) is the static force response of the bushing.
The effective stiffness K and effective damping C are dependent on nonlinear effects such as friction in the bushing material and other nonlinear behavior that cannot be easily represented physically.
- The effective stiffness K is
multiplied by a factor:
- Similarly, the effective damping C is
- Static force at the operating point: Spline (X)
- Force due to the dynamic behavior of the bushing:
