Fit Data
Select the Fit Data tab.
If your project uses a rubber bushing, then the following page appears:Figure 1.Figure 2.
Click on Initial GBS File to locate the appropriate
file.
The fitting algorithm requires an initial set of model parameters to initiate the fitting. These parameters are contained in the Initial .gbs file. The software searches for a .gbs file with the same prefix as the Application_Type field specified in the .spd file. The default model that is used is based on the Application_Type in the .spd file. If the software does not find the Initial .gbs file, it uses a default Initial .gbs file from the installation. The set of values in the default Initial .gbs file generally works for most fitting tasks; however, you have the option to provide your own Initial .gbs file.
Click on OPT File to locate the appropriate file.
To control the fitting, the fitting algorithm requires upper- and lower-bound values for the model parameters. These values are located in the .opt file. The software searches for an .opt file with the same prefix as the Application_Type field specified in the .spd file. If the software does not find an .opt file, it uses a default .opt file from the installation. The set of optimization parameters in the default .opt file generally works for most fitting tasks, however, you have the option to provide your own .opt file.
Click View design parameters to view the model
parameters and optimization settings as you see in the following image. You can
modify the parameters as required. Modified values are sent to the fit
tool.
Figure 3.
- Click the direction sub tabs FX, FY, FZ, TX, TY, TZ to select any active direction. A direction is active if the .spd file contains data for this direction. The information in the Direction sub tabs comes from the .gbs and .opt files that were loaded. You can view and modify the optimization parameters in these tabs.
- Click the appropriate bushing model radio button to specify the bushing model for fitting. If the selected .gbs and .opt files include the values for this model, the values are loaded in the table. If the values are not loaded, you have to enter them. Note that the software automatically selects the correct bushing model for you so that you do not need to toggle between the models.
- Use the Parameter table to change the initial model values imported from the Initial .gbs files, and the upper and lower bounds for each of the parameters as specified in the .opt file.
- In the # Processes field, enter the number of sub-processes for the fit operation. If you enter 1 for this option, MIT runs using a single process. For any value greater than 1, MIT uses multiple sub-processes. MIT automatically configures the number of sub-processes to use.
- Click Fit <direction> to run the Fit for a selected direction. Each Fit is considered as a cycle in the Review tab. You can submit jobs while a Fit job is running.
