Export Data
- .export.gbs
- .export.pdf
The five main functions of this tab include:
Experiment Selection
- A table on the Export Data tab lets you select a subset of reviewed data for creating a bushing. You can export only one bushing at a time.
- A bushing is identified by its Application_Type attribute in the .spd file. All experiments in the Review tab with the matching Application_Type are populated in the top left table. If the Application_Type field is left blank, all data in the Review tab is loaded.
- The average of the Dynamic Stiffness fit score and Loss Angle fit score is displayed in parenthesis. You can use these scores to gauge the quality of the fit. The Application_Type for an Analyze operation is always blank.
- Data in the experiment selection table is preloaded to minimize user interaction. Cells that have only one value are non-editable. When only one experiment and one cycle are loaded in the Review tab, all cells are non-editable.
Activity Table
The Activity Table defines the bushing stiffness and damping options that are active in the .gbs file. The table opens with default values loaded, which you can modify.
- You can select only a single stiffness and a single damping model for each direction.
- Models are grayed out when they are not valid for a certain direction.
Static Properties
- Representation of Static Data
- MIT supports three equivalent but alternate representation for static
data:
- Spline Data
- This is the data obtained from the static testing of the physical bushing. This data is copied from the input .spd file.
- Conceptual Cubic
- This is a cubic polynomial, based on the physical data that approximates the spline data. For more details, see: View Data.
- Constant Stiffness
- This value represents a linear fit to the spline data. For more details, see: View Data.
- Static Properties
- You can edit static data after selecting the Change Static Properties box.
You can specify the data to be exported by selecting the radio buttons for
any given direction.
- Conceptual Cubic
- This data is calculated from the static data in the
.spd file.Note: If no .spd file is available when the ANALYZE process is performed, then the conceptual cubic fields are non-editable and are excluded from the output .gbs file.
- Constant Stiffness and Damping
- The default is 0.0 when no experiment or .spd field is available in a certain direction.
- Constant Damping
- The default is assumed to be 0.1% of the Constant Stiffness.
- Resetting Parameters
- The Reset button lets you revert back any changes to the values of the static parameters to the original values.
Output Units
Mass | Length | Time | Force | Angle |
Kilogram | Millimeter | Second | Newton | Degrees |
Gram | Meter | KiloNewton | Radians |
Export
- Shortcuts to Extract a PDF File from a GBS File
- The mit_decodeReport.py is a Python script that extracts a fit report from
the .gbs file and outputs it as a
.pdf file. To enable quick access to the
mit_decodeReport.py, you can define shortcuts
as follows:
- Windows
- Go to <HW_Installation/utility/scripts/plotting/mit/batch/
- Right-click mit_decodeReport.py, and then select Send to>Desktop.
- Linux
- Use the ln -s command to create a symbolic link to <HW_Installation/utility/scripts/plotting/mit/batch.
- Note that Windows style path names with "\" are allowed.
- Note that a path name with blanks is allowed provided the path name is enclosed in double quotes as follows: "C:\test directory\testName".
- Command Summary
- The Export Data options are:
mit_decodeReport -i <gbs-file-name> -o <output_directory> <options>
- Arguments
- The following are arguments for Export Data:
Table 2. Argument Description -i <gbs-file-name> Specifies a .gbs file, generated by the MIT, that is to be provided as input to the script. -o <output-file-name> Specifies the name of the output .pdf file to be generated. When this argument is not specified, the prefix of the .pdf is obtained from the prefix of the input .gbs file. -h Provides information about how to use this utility. Invoking mit_batch without any parameters also provides help content. - Examples
- The following are examples of Export Data usage:
- mit_decodeReport.py -i C:/input.gbs
- Decode the .gbs file, C:/input.gbs, and generate a .pdf file, C:/input.pdf, in the same directory where the .gbs file is present.
- mit_decodeReport.py -i C:/input.gbs -o C:/output/rubber.pdf
- Decode the .gbs file, C:/input.gbs, and generate a .pdf file, rubber.pdf, in the directory, C:/output.
- mit_decodeReport.py -i C:/input.gbs -o C:/output/test
- Decode the .gbs file, C:/input.gbs, and generate a .pdf file, test.pdf, in the directory, C:/output.
Note: If Python is not installed on your system, then include the location of Python in your path as follows:- Windows
- set PATH <HW_INSTALLATION>/hw/python/python27/win64:%PATH%
- Linux
- setenv PATH
<HW_INSTALLATION>/hw/python/python27/win64:$PATH
- The system does not know that files with the
.py extension are Python files. Therefore,
invoke mit_decodeReport.py as
follows:
python.exe mit_decode.py -i C:/input.gbs -o C:/output.gbs
- Windows style path name with "\" are allowed.
- Blanks in paths are allowed inside of double quotes: "C:\test directory\testName".
- The default .xml file contains only MIT options. You cannot specify path names for input and output files in this file.
follows:
- PDF with Logo and Copyright Information
- You an include logo and copyright information in your .pdf report using
a preference file. The contents of the preference file includes:
# Define the HyperWorks version number *Id(HyperWorks 2019) # Define the pathname to logo file {logo_file = "\"AltairPrimary-50.png\""} # Define a short copyright message {crght = "\"\""} #Include but DO NOT change the lines below *BeginInterpreter("tcl") set t [::hw::GetT] hwi GetSessionHandle sess$t sess$t SetUserVariable mit_report_logo {logo_file} sess$t SetUserVariable mit_report_copyright {crght} sess$t ReleaseHandle *EndInterpreter()
- Steps to Include a Preference File in a .pdf
- Create an ASCII file in a directory. You can name the file as you like, for example: mit_pdf_preferences.mvw.
- Copy into the ASCII file the text displayed above.
- Specify the full path name for the logo file as a value for the variable logo_file.
- Specify appropriate text to use as a value for the variable cright.
- Save the file.
- Set the value of the environment variable
HW_CONFIG_PATH to the preference file name:
- Bash Shell
- HW_CONFIG_PATH = "C:\Documents\utilities\mit_pdf_preferences.mvw"
- C Shell
- setenv HW_CONFIG_PATH "/usr/fred/utilities/mit_pdf_preferences.mvw"
- After you restart MIT, MIT exports a .pdf file containing the specified logo and copyright.
