OS-V: 0400 Pin-ended Double Cross
                           Test No. FV2 A pin-ended double cross, in-plane         vibration problem. OptiStruct is used to investigate the         coupling between flexural and extensional behavior, as well as the repeated and closed
                              eigenvalues of the double cross in Normal Modes Analysis.
