This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
AeroDyn Libraries MotionSolve supports the AeroDyn libraries for aero-elastic analysis of wind turbines.
Co-simulation Introduction
Co-simulation is a simulation methodology that allows complex systems comprised of subsystems to be easily simulated.
Co-simulation Using TCP/IP
Inter-Process Communication (IPC) co-simulation allows co-simulation to run on the same machine, as well as between different machines/platforms.
Couple MotionSolve with Twin Activate MotionSolve can interface with Twin Activate, an open and flexible integration platform for comprehensive system-of-systems simulation.
Couple MotionSolve with EDEM MotionSolve can interface with Altair EDEM, a state-of-the-art bulk material simulation tool.
Couple MotionSolve with OptiStruct MotionSolve can interface with OptiStruct, a state-of-the-art optimization-enabled structural analysis tool.
Couple MotionSolve with VEOS MotionSolve interfaces with dSPACE VEOS, a PC-based simulation platform for ECU software validation.
