Processing math: 100%
BISTOP
The BISTOP function models a gap element.
Bistop(x,˙x,x1,x2,k,e,cmax,d)
It can be used to model forces acting on a body while moving in the gap between two boundary surfaces, which act as elastic bumpers. The properties of the two boundary surfaces can be tuned as desired.
Arguments
x
The expression used for the independent variable. For example, to use the z-displacement of I marker with respect to J marker as resolved in the reference frame of the RM marker as the independent variable, specify x as DZ({marker_i.idstring}, {marker_j.idstring}, {marker_rm.idstring}).
˙x
The time derivative of the independent variable. For example, if x is specified as above, then ˙x will be VZ({marker_i.idstring}, {marker_j. idstring}, {marker_rm.idstring}).
x1
The lower bound of x . If x is less than x1 , the bistop function returns a positive value. The value of x1 must be less than the value of x2 .
x2
The upper bound of x . If x is greater than x2 , the bistop function returns a negative value. The value of x2 must be greater than the value of x1 .
k
The stiffness of the boundary surface interaction. It must be non-negative.
e
The exponent of the force deformation characteristic. For a stiffening spring characteristic, e must be greater than 1.0 and for a softening spring characteristic, e must be less than 1.0. It must always be positive.
cmax
The maximum damping coefficient. It must be non-negative.
d
The penetration at which the full damping coefficient is applied. It must be positive.
Definition
(1)
Bistop={max(k*(x1-x)e-Step(x,x1-d,cmax,x1,0)*˙x,0),if x<x10, if x1≤x≤x2min(-k*(x-x2)e-Step(x,x2,0,x2+d,cmax)*˙x,0),if x>x2
<Force_Vector_TwoBody
     id                    = "30101"
     type                  = "ForceOnly"
     i_marker_id           = "30102031"
     j_floating_marker_id  = "30101031"
     ref_marker_id         = "30101010"
     fx_expression         = "BISTOP(DX(30102030,30101010,30101010),VX(30102030,30101010,30101010),0.5,9.5,10000000,2.1,1,0.001)"
     fy_expression         = "0"
     fz_expression         = "0"
