In this tutorial, you will learn how to build a model using the Assembly and Task Wizards in MotionView, how to view a standard report, and how to modify a model and compare results using the Report Template.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
MV-1032: Build Models and Simulations Using Wizards
MV-1040: Build Models Using Tcl
In this tutorial, you will learn how to work with the application's Tcl interface and how to build a simple model using Tcl commands.
MV-1050: Automate Using TCL
In this tutorial, you will invoke a TCL script from MotionView and link the script to a menu item on the menu bar.
