In this tutorial you will learn how to use the Load Export utility to bridge the gap between Multibody Dynamics (MBD)
analysis and Finite Element (FE) analysis in MotionView.
In this tutorial, you will learn how to convert results simulation run into file formats that can be used for fatigue
analysis (using a tool like NCode) and how to write a fatigue analysis file from the MotionView animation window.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
MV-3030: Load Export
In this tutorial you will learn how to use the Load Export utility to bridge the gap between Multibody Dynamics (MBD) analysis and Finite Element (FE) analysis in MotionView.
MV-3040: Durability and Fatigue Tools
In this tutorial, you will learn how to convert results simulation run into file formats that can be used for fatigue analysis (using a tool like NCode) and how to write a fatigue analysis file from the MotionView animation window.
