ALE Interfaces
Block Format Keyword
Several specific ALE interfaces are available in Radioss. They could be used for Fluid-structure interaction (Arbitrary Lagrangian Eulerian elements to interact with Lagrangian elements) or Fluid to fluid interaction, which is used to transmit the flow between two ALE surfaces.
ALE Interface Types
| Contact Treatment | Types | Application | Description | |
| ALE | Tied | TYPE1 | Fluid structure interaction | Boundary between an ALE material and a Lagrangian material. |
| Slide / Void | TYPE9 | Fluid structure interaction | ALE/Lagrange, with void opening and free surface. | |
| FLUID / FLUID | TYPE12 | Fluid to fluid contact | Connects two fluid meshes with free, tied or periodic
options. ALE or EULER or LAG/ALE or EULER or LAG |
| Slide / Void | TYPE18 | Fluid structure interaction | Coupling between a Lagrangian material and an ALE material. | |
| Slide / Void | TYPE22 | Fluid structure interaction | Coupling between a Lagrangian material and an ALE material. |
