/GRTRUS/TRUS
Block Format Keyword Describes the truss groups.
| /GRTRUS/TRUS/grtruss_ID/unit_ID | |||||||||
| grtruss_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grtruss_ID | Truss group identifier (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grtruss_title | Truss group title (Character, maximum 100 characters) |
| item_ID1, item_ID2,... item_IDn | List of truss
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
