*PART
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *PART_{OPTION1}_{OPTION2} | |||||||
| part_title | |||||||
| part_ID | sec_ID | mat_ID | |||||
| XCOG | YCOG | ZCOG | TM | node_ID | |||
| IXX | IXY | IXZ | IYY | IYZ | IZZ | ||
| VTX | VTY | VTZ | VRX | VRY | VRZ |
| Thick |
Definition
| OPTION1 |
| OPTION2 |
| part_title | Component title. (Character, maximum 80 characters) |
| part_ID | Part identifier. (Integer) |
| sec_ID | Section identifier of the elements in the
part. (Integer) |
| mat_ID | Material identifier of the elements in the
part. (Integer) |
| XCOG, YCOG, ZCOG | Coordinates of part center of gravity. Default = 0 (Real) |
| TM | Mass of rigid part. Default = 0 (Real) |
| node_ID | Node number for part center of
gravity. (Integer) |
| IXX, IXY, IXZ, IYY, IYZ, IZZ | Inertia tensor of the rigid body. Default = 0 (Real) |
| VTX, VTY, VTZ | Initial translational velocity applied to the rigid
component. Default = 0 (Real) |
| VRX, VRY, VRZ | Initial rotational velocity applied to the rigid
| Thick | Optional part thickness in contact. Default = 0 (Real) |
