/TRANSFORM/SYM
Block Format Keyword Defines a symmetry for a node group normal to the plane defined by a vector.
| /TRANSFORM/SYM/transform_ID/unit_ID | |||||||||
| transform_title | |||||||||
| grnd_ID | X_point_1 | Y_point_1 | Z_point_1 | node_ID1 | node_ID2 | ||||
| X_point_2 | Y_point_2 | Z_point_2 | |||||||
Definition
| transform_ID | Transformation
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| transform_title | Transformation
| grnd_ID | Node group identifier.
2 (Integer) |
| X_point_1 | X coordinate of point
1. Default = 0.0 (Real) |
| Y_point_1 | Y coordinate of point
| Z_point_1 | Z coordinate of point
| node_ID1 | Node identifier
1. (Integer) |
| node_ID2 | Node identifier
2. (Integer) |
| X_point_2 | X coordinate of point
2. Default = 0.0 (Real) |
| Y_point_2 | Y coordinate of point
| Z_point_2 | Z coordinate of point
- If node_ID1 and node_ID2 are
defined, the symmetry will be done on the plane normal to the vector defined by
node_ID1 and node_ID2. The
plane includes node_ID1. If only one node is defined, the error message is displayed.
Otherwise, the symmetry will be done on the plane normal to the vector defined by point_1 and point_2. The plane includes the point_1.
- Transforms applied to node groups only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed.
