Inspire is a concept design tool, which you can use to run structural optimization, finite element analysis, motion analysis,
and additive manufacturing analysis.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may
be drawn. These features will be checked out for the duration of the session.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
What is Altair Inspire? Inspire is a concept design tool, which you can use to run structural optimization, finite element analysis, motion analysis, and additive manufacturing analysis.
Videos: Getting Started with Inspire
A series of videos introducing the view controls, 3D modeling, structural analysis, topology optimization, and PolyNURBS.
Licensing Features
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may be drawn. These features will be checked out for the duration of the session.
