Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials,
modify the environment, and change the camera position.
Interactive Rendering
Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials, modify the environment, and change the camera position.
Editors
Configure materials, the environment, lights, labels, the camera position, and the rendering settings.
Libraries
The Render Library contains preset and saved custom materials, environments, and models.
Render
Create a final rendered image. Learn how to adjust the rendering settings and change rendering engines.
