Display Currents Dialog
Review the current waveform of selected net or selected segment in time domain and frequency domain.
- Waveform Type: You can select waveform type. The time-domain or frequency-domain.
- Currents At: You can view net result or segment result. When All segments option is selected, the results of all selected nets in the Net Name Tree region are displayed. When selecting the Selected segments option, you must click the desired segment on the screen to select it.
- Display: Display result in pre-selected format.
- Net name tree region: All nets belong to simulated model are listed here.
Upon selecting Waveform Type as Frequency-Domain and clicking Display menu, the Radiated Emission Frequency-Domain Viewer will be open and current of net will be displayed in frequency based. The current magnitude values among ports are initially displayed.
- Current waveform display region.
- Select the display type to be displayed.
- Toggle on and off to display certain desired waveform.
- Frequency scale: Linear or Log.
- Value scale: Linear or Log.
