Board Component Clearance
This DFE rule checks whether components are placed enough distance away from board edges.
- Item: Enter the item name.
- Component Group: Select a component group or groups.
- Clearance: Assign a minimum allowable distance from board edges.
- Component Measure-Base: Define component measure base. (COC, Silk, PAD, Silk+Pad)
- Component Type: Select the component's type. (SMD or DIP)
- Board Outline: The board outline consists of two lines. Select the outline
reference. (Edge/Center)
- Edge: Select the outer line. The outer line of the lines is considered as the outline.
- Center: The middle of the two lines is regarded as the outline.
20-H Rule
- Extend the ground plane about 20 times of the layer spacing (H) between the power plane and ground plane from the edge or power plane.
