Regular Connections
Regular connections can be used to define contact-based connections between parts in an assembly.
Connection Resolution
Connection resolution defines the mathematical completeness of the connection entity. Three settings are possible: Normal, Increased, and High. While details of the equations are not important to the user, you will need to be aware of regions where connections may not be adequately defined.
Fastener Connections
Regular connections around bolts, nuts and washers are grouped under fastener connections.
