2023
Information about treatment and properties of geometric entities in SimSolid.
View new features for SimSolid 2023.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Options for defining treatment of geometry before import.
Material properties define the structure and thermal characteristics of each part in the assembly.
SimSolid allows for the visualization of raw STL data exported from a CAD system.
Directly access models from the cloud-based CAD system Onshape.
Connect to existing Teamcenter instances and query for and retrieve CAD files directly into SimSolid.
Summary of the file formats supported for CAD integration in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
ON THIS PAGE
