SS-T: 4055 Structural Thermal Imported Analysis
Create a structural thermal imported analysis, and then create and link to a thermal-stress analysis SimSolid.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Learn to create and link thermal imported analysis.
- Model Description
- The following model file is needed for this tutorial:
- ThermalImported.ssp
Open Project
- Start a new SimSolid session.
On the main window toolbar, click Open Project
- In the Open project file dialog, choose ThermalImported.ssp
- Click OK.
Create Thermal Analysis
Run Analysis
- On the Project Tree, open the Analysis Workbench.
Click
(Solve).
Review Results
Create Structural Thermal Analysis and Define Thermal Load
Define Immovable Support
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
Run Analysis
Click
(Solve).
