Use the MAT Explorer interface to explore and load variables from a .MAT file, providing a visual way to see the contents of a .MAT file and to import variables into an OML session.
Group multiple blocks in a diagram to create a super block.
Select a group of blocks in your model that you want to consolodate into a
super block.
The following figure shows an example diagram of a PID controller that
is a good candidate to be a super block.
Once added to a block library as a super block, the controller can be
easily reused in other models.
On the ribbon, select the Super Block tool: , or right-click and from the context menu, select Super
Block.
The selection of blocks is consolodated into a single super block:
The new super block acts like a basic block. You can name it, define
parameters for it, and save it for reuse in new models.
