Expanding and Extracting Super Block Contents
Expand a super block and extract the contents into your model.
The Expand Super Block option expands a super block, copies the content into the current model, and eliminates the super block. The copied content remains selected so that you can move it freely to a desired location in the model. Any context associated with the primary super block is removed. This option does not apply to masked super blocks.
To activate Expand Super Block, select a super block, then press Ctrl+Alt+X. Alternatively, on the super block, right-click, and from the context menu, select Expand Super Block.
If the super block includes a context, a warning is issued that the context will be lost.
