Flow Simulator
Flow Simulator
2023.1
  1. Home
  2. Solver Technical Manual
  3. Elements
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
  • Graphical User Interface
  • Solver Technical Manual
  • Flow Simulator General Guide
Index
Flow Simulator
2023.1
Flow Simulator
  • What's New
    View new features for Flow Simulator 2023.1.
  • Get Started
    Flow Simulator is an integrated flow, heat transfer, and combustion design software that enables multidisciplinary engineering simulations to optimize machine design.
  • Tutorials
    Discover Flow Simulator functionality with interactive tutorials.
  • Quick Start Guide
    • General Overview
    • Inbuilt Material Properties
    • Chambers
    • Elements
      • Elements Overview
      • Advanced Orifice Element
      • Bearing Elements
      • Bend Elements
      • Brush Seal Element
      • Centrifugal Pump Elements
      • Combination Flow Elements
      • Combustion Element
      • Diffuser Element
      • Disk Pumping
      • Effective Area Orifice Elements
      • Elevation Element
      • Fan, Compressors, and Turbine Elements
      • FI CdComp Elements
      • Fixed Flow Elements
      • Incompressible Tube Element
      • Junction Elements
      • Labyrinth Seal Tooth by Tooth Element
      • Naca Scoop Element
      • Orifice Element
      • Orifice Plates
      • Positive Displacement Pump Element
      • Spline Seal Element
      • Supersonic Tube
      • Transition Elements
      • Tube Elements
      • Turbulator Passage Elements
      • Valve Elements
      • Vermes Seal Element
      • Vortex Elements
      • WSeal Element
    • Components
    • Cavities
    • Thermal Network
    • Controllers
    • User Defined Element (UDE)
    • General Functions and Routines
    • References
Flow Simulator
Flow Simulator
2023.1
  1. Home
  3. Elements
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
Index
Elements
  1. Elements Overview
  2. Advanced Orifice Element
  3. Bearing Elements
  4. Bend Elements
  5. Brush Seal Element
  6. Centrifugal Pump Elements
  7. Combination Flow Elements
  8. Combustion Element
  9. Diffuser Element
  10. Disk Pumping
  11. Effective Area Orifice Elements
  12. Elevation Element
  13. Fan, Compressors, and Turbine Elements
  14. FI CdComp Elements
  15. Fixed Flow Elements
  16. Incompressible Tube Element
  17. Junction Elements
  18. Labyrinth Seal Tooth by Tooth Element
  19. Naca Scoop Element
  20. Orifice Element
  21. Orifice Plates
  22. Positive Displacement Pump Element
  23. Spline Seal Element
  24. Supersonic Tube
  25. Transition Elements
  26. Tube Elements
  27. Turbulator Passage Elements
  28. Valve Elements
  29. Vermes Seal Element
  30. Vortex Elements
  31. WSeal Element
